Hi
I have a swift from 2015 style with a adayo ce4kt7/ce4kx4 (in-touch) radio system with GPS. problem now is, a have lost my micro sd card, unfortunately i have no back up of the map, is there any suggestion on what to do?
By the way i am from Denmark
Threads: 110
31-03-2024, 01:54
(This post was last modified: 31-03-2024, 02:05 by Leibniz.)
Your system works with windows 6.0 OS, so you could go for IGO navigation that works with your system. It has to be IGO navigation for windows 6.0 and not Igo android, that will not work.Maybe it's better to check out a Chinese android navigation system for your car, more freedom of choice what navigation to use and more versatile as well. If you want to use the system in your car try with a search engine: Igo8 navi windows 6.0 . Try on ebay, or Amazon they might have something. But best to buy an android navigation on Banggood or so, works fine I bought one on Banggood. Good luck and welcome on the forum.
(31-03-2024, 01:54)Leibniz Wrote: Your system works with windows 6.0 OS, so you could go for IGO navigation that works with your system. It has to be IGO navigation for windows 6.0 and not Igo android, that will not work.Maybe it's better to check out a Chinese android navigation system for your car, more freedom of choice what navigation to use and more versatile as well. If you want to use the system in your car try with a search engine: Igo8 navi windows 6.0 . Try on ebay, or Amazon they might have something. But best to buy an android navigation on Banggood or so, works fine I bought one on Banggood. Good luck and welcome on the forum.
Thank you
