Hi I have a 2018 Baleno here in the Netherlands with a really old firmware on it (I think version 840 or 850). Will 1860.2 update work ok on my car or do I run a risk of "bricking" the system.
Many Thanks
SteveJ
I think it should work, here is the link to the topic on this forum:
https://www.suzukiclubnederland.nl/forum...?tid=28334
It's in Dutch language, I am not sure how good your Dutch skills are.If you enter in search window of this forum '1860.2' you may find more info. Keep in mind that any update is at your own risk. At
www.Marktplaats.nl you may find it cheaper than at your local dealer, but again at your own risk, no warranty here. Good luck.
(21-03-2019, 13:31)Leibniz Wrote: I think it should work, here is the link to the topic on this forum: https://www.suzukiclubnederland.nl/forum...?tid=28334
It's in Dutch language, I am not sure how good your Dutch skills are.If you enter in search window of this forum '1860.2' you may find more info. Keep in mind that any update is at your own risk. At www.Marktplaats.nl you may find it cheaper than at your local dealer, but again at your own risk, no warranty here. Good luck.
Many thanks for your help
